16 years agouClinux-dist-20100315 make vendor_hwselect
hi,everyone! i am using "uclinux-dist-20100315.tar.bz2"downloaded fromhttp://www.uclinux.org/pub/uclinux/dist/ (http://www.uclinux.org/pub/uclinux/dist/).i build my niosii system in sopcbuilder...
16 years ago --- Quote Start --- Did you run make menuconfig first? --- Quote End --- thank you for your reply !yes,i make munuconfig as follow: Vendor/Product Selection ---> --- Select the Vendor you wish to target Vendor (Altera) ---> --- Select the Product you wish to target Altera Products (nios2) ---> Kernel/Library/Defaults Selection ---> --- Kernel is linux-2.6.x Libc Version (None) ---> [*] Default all settings (lose changes) [ ] Customize Kernel Settings [ ] Customize Vendor/User Settings [ ] Update Default Vendor Settings then make vendor_hwselect sysptf=/usr/local/src/niosii.ptf. there are so many things to be customed.why?
