16 years agouClinux-dist-20100315 make vendor_hwselect
hi,everyone! i am using "uclinux-dist-20100315.tar.bz2"downloaded fromhttp://www.uclinux.org/pub/uclinux/dist/ (http://www.uclinux.org/pub/uclinux/dist/).i build my niosii system in sopcbuilder...
16 years ago --- Quote Start --- This is embedded Linux. -Michael --- Quote End --- But as a green figure,when "make menuconfig",I left almost everything default as follow: Kernel Version (linux-2.6.x) ---> Libc Version (None) ---> glibc Library Configuration (if selected) ---> [*] Default all settings (lose changes) [ ] Customize Kernel Settings [ ] Customize Application/Library Settings [ ] Update Default Vendor Settings There should be not so many things to be customed , isn't it?
