UBIFS build error
I am getting the following compile error after trying to enable UBIFS:
mkfs.ubifs.h:48:23: error: uuid/uuid.h: No such file or directory I am fairly new to uClinux. I am investigating porting our current application running under uCOSII to uCLinux due to networking issues with uCOSII and the InterNiche stack. My development host is running Ubuntu 9.10. I have followed the examples on the nioswiki and now have uClinux running on our custom board and booting uCLinux from flash with uBoot (uBoot is in the EPCS). I decided having a flash filesystem would be really useful in our application so I started looking at using UBIFS. Before enabling UBIFS I first performed the "git pull" to be sure I had the latest source: update git to the latest After you have first successful boot, you may use "git pull" to update the kernel and uClinux-dist. Please refer to GitServer. cd uClinux-dist git pull cd .. cd linux-2.6 git pull cd .. I followed the UBIFS instructions but the first sign of trouble came when I could not find the UBIFS utilities in the configuration manager. Next in the User apps configuration menu, go to "Flash Tools" ---> [*] "mtd-utils" --> [*] " ubifs utilities" . I continued on without it but now I get the compilation error shown at the top. Anyone have any ideas or seen this? Thanks Tim8 Replies
Ah, I did it with MMU. The "test-nios2" and "unstable" branches of uClinux-dist are a bit old.
If you can afford 2K LE, please try MMU. Otherwise, please switch the branch of uClinux-dist to "trunk". In vendors/Altera dir, cp -a nios2nommu mynios2, select mynios2 and change init shell to sash. - Hippo - Altera_Forum
Thanks Hippo. Unfortunately, I am not sure I understand all of your instructions. I am pretty new to uClinux so you may have to be more explicit on how to perform the steps you described above. I found the vendors/Altera directory under uClinux-dist but I only have a directory of nios2 there. Not sure how to 'switch the the branch to "trunk"'. Sorry to be a bother.
I did this under uClinux-dist: $git branch * test-nios2 $git checkout -b trunk Switched to a new branch 'trunk' $git pull remote: Counting objects: 15, done. remote: Compressing objects: 100% (8/8), done. remote: Total 8 (delta 6), reused 0 (delta 0) Unpacking objects: 100% (8/8), done. From git://sopc.et.ntust.edu.tw/git/uClinux-dist 82a6374..4843bae trunk -> origin/trunk You asked me to pull without telling me which branch you want to merge with, and 'branch.trunk.merge' in your configuration file does not tell me either. Please specify which branch you want to merge on the command line and try again (e.g. 'git pull <repository> <refspec>'). See git-pull(1) for details. If you often merge with the same branch, you may want to configure the following variables in your configuration file: branch.trunk.remote = <nickname> branch.trunk.merge = <remote-ref> remote.<nickname>.url = <url> remote.<nickname>.fetch = <refspec> See git-config(1) for details. Tim - Altera_Forum
Please try this,
cd uClinux-dist git fetch origin git checkout -b trunk origin/trunk It would be helpful to take some git tour. - Hippo - Altera_Forum
Thanks Hippo. All is good for now. I will try to find some more git server tour websites...
Tim - Altera_Forum
Great. For git tour, please check out,
http://git-scm.com/ - Hippo - Altera_Forum
Thanks for the git reference Hippo.
I guess I spoke too soon about all being good... I am now getting the following error during the compile: boa.elf2flt(.text+0x148c): In function `main': /home/****ett/nios2/nios2-linux/uClinux-dist/user/boa/boa-0.94.14rc21/src/boa.c:94: undefined reference to `daemon' collect2: ld returned 1 exit status make[6]: *** [boa] Error 1 make[6]: Leaving directory `/home/****ett/nios2/nios2-linux/uClinux-dist/user/boa/build-boa-0.94.14rc21/src' make[5]: *** [boa] Error 2 make[5]: Leaving directory `/home/****ett/nios2/nios2-linux/uClinux-dist/user/boa/build-boa-0.94.14rc21' make[4]: *** [pre-build] Error 2 make[4]: Leaving directory `/home/****ett/nios2/nios2-linux/uClinux-dist/user/boa' make[3]: *** [all] Error 2 make[3]: Leaving directory `/home/****ett/nios2/nios2-linux/uClinux-dist/user/boa' make[2]: *** [boa] Error 2 make[2]: Leaving directory `/home/****ett/nios2/nios2-linux/uClinux-dist/user' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/****ett/nios2/nios2-linux/uClinux-dist/user' make: *** [subdirs] Error 1 I tried disabling boa (although I would prefer having it eventually) and got a little farther but then got an error regarding the cgi-demo: romfs-inst.sh /home/httpd/cgi-bin/cgi_demo cp: cannot create regular file `/home/****ett/nios2/nios2-linux/uClinux-dist/romfs/home/httpd/cgi-bin/cgi_demo': No such file or directory Any thoughts? Thanks, Tim - Altera_Forum
I did a quick we search on the problem just stated above with boa and found this:
--- Quote Start --- daemon is a C library function used to fork a process into the background (daemonize). This function is not supported on NOMMU architectures like MicroBlaze. I do not use busybox's HTTPD, but rather recommend using thttpd or fnord. fnord is my preference if you are doing any serious CGI due to some other NOMMU-related issues in thttpd's handing of get/post methods. Try disabling busybox's httpd option, and enable fnord in the menu config. Do "make user_only" *twice* (due to busybox build issues), remove the petalinux-dist/romfs directory, then run "make romfs image". From memory the fnord config file is identical syntax - it's very easy to get going. --- Quote End --- So I disabled httpd in BusyBox --> Networking Utilites and boa under Network Applications and enabled fnord under Network Applications. I also disabled generic-cgi under Miscellaneous Configuration. Now everything compiles ok but I have not yet tried this new build on my target. If this doesn't sound like the best approach, please advise otherwise. I really appreciate all the help with this. Thanks. Tim - Altera_Forum
I think fnord can be used instead of boa, though I didn't try it yet. Please let me know if it work. We shall update the wiki on this.
Cheers. Hippo
