16 years agoUBIFS build error
I am getting the following compile error after trying to enable UBIFS: mkfs.ubifs.h:48:23: error: uuid/uuid.h: No such file or directory I am fairly new to uClinux. I am investigating por...
16 years agoAh, I did it with MMU. The "test-nios2" and "unstable" branches of uClinux-dist are a bit old.
If you can afford 2K LE, please try MMU. Otherwise, please switch the branch of uClinux-dist to "trunk". In vendors/Altera dir, cp -a nios2nommu mynios2, select mynios2 and change init shell to sash. - Hippo
