20 years agoU-Boot for Stratix II
can anybody tell me how to install U-Boot on a Stratix II (2s60es) board ? Thanks7 Replies
Hi MFM,
> how to install U-Boot on a Stratix II 1. Download the u-boot source archive from: http://www.psyent.com/download (http://www.psyent.com/download) 2. Decompress and review the files USING.txt and BUILDING.txt in the top directory. 3. Edit the file include/configs/EP1C20.h to match your hardware. 4. Edit the file board/altera/common/AMDLV065D.c so the flash_init routine is just: unsigned long flash_init (void) { return (CFG_FLASH_SIZE);} 5. Build u-boot: $ make distclean $ make PK1C20_config $ make At this point you should be able to download u-boot and get a command prompt. You'll have enough to start playing around with u-boot. When you're ready to actually do a full port, read the u-boot README file, then if you need help, make another post (or you can PM me) -- I'll be glad to help. If you simply use an existing board as an example, you should have no problems. Regards, --Scott - Altera_Forum
Hi Scott,
I sent you a PM with no reply http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif . Well, I've done what you suggested, the build was successful. But when I try to program u-boot into flash like in the using.txt, the console display an error message <div class='quotetop'>QUOTE </div> --- Quote Start --- Communication port must be specified. Use openport <port> to configure the communication port[/b] --- Quote End --- I tried the openport command and I've got a window error : Driver open failed I'm wondering if I could use my usb blaster, instead of the serial cable, and the flash programmer to program u-boot into flash memory, cause I tried to do so too but without any success. thanks for your help. Warm Regards - Altera_Forum
Hi MFM,
> I sent you a PM with no reply Sorry for the delay ... ... but please be patient -- I don't get paid for my participation on the forum -- and I often get bogged down doing the _other_ stuff that let's me & the family eat ;-) I'll always do my best to respond though. > I'm wondering if I could use my usb blaster, instead of the serial cable, and the > flash programmer to program u-boot Yes. You can use the JTAG UART as the u-boot console and the flash programmer to program u-boot into flash. Until you have your flash driver working, the flash programmer is the best bet. Once you have your flash driver working, the u-boot tftp and flash programmer is much faster. Regards, --Scott - Altera_Forum
i download the source,but the erros occured again! could you give me the EP1C20_config.h file that have changed according to the std_2c35.ptf!
thank you ! - Altera_Forum
What errors occurred? - Altera_Forum
--- Quote Start --- originally posted by smcnutt@Jun 13 2006, 09:43 AM > i download the source,but the erros occured again!what errors occurred?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16137)
--- quote end ---
--- Quote End --- What is PM??
--- Quote Start --- originally posted by park5647+aug 24 2006, 04:35 pm--><div class='quotetop'>quote (park5647 @ aug 24 2006, 04:35 pm)</div>--- quote start ---
<!--quotebegin-smcnutt@Jun 13 2006, 09:43 AM > i download the source,but the erros occured again!
--- quote end ---
--- Quote End --- What is PM?? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17810)</div> [/b] --- Quote End --- Personal Message
