20 years agoU-Boot for Stratix II
Hi, can anybody tell me how to install U-Boot on a Stratix II (2s60es) board ? Thanks
20 years agoHi Scott,
I sent you a PM with no reply http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif . Well, I've done what you suggested, the build was successful. But when I try to program u-boot into flash like in the using.txt, the console display an error message <div class='quotetop'>QUOTE </div> --- Quote Start --- Communication port must be specified. Use openport <port> to configure the communication port[/b] --- Quote End --- I tried the openport command and I've got a window error : Driver open failed I'm wondering if I could use my usb blaster, instead of the serial cable, and the flash programmer to program u-boot into flash memory, cause I tried to do so too but without any success. thanks for your help. Warm Regards
