The Highest Carrier Frequency for Stratix III
Dears All,
Greetings, I was just wondering about how high I can get as an output from the the Stratix III Development Kit as a carrier frequency. I know I can use two ways to generate that signal using (nco or .mif file for the simulated signal from Matlab), and I'm really hoping to get something close to 1GHz (for example) if it possible! Thank you for your consideration :)17 Replies
to get 1GHz carrier then you need sampling freq of 2GHz at least i.e. just output +1/-1 (no need for LUT or NCO).
Can you get Fs of 2GHz. Certainly not in the logic fabric but may be in the serdes sections. However what do you want to do with carrier. You need to carry some signal on it(modulate). Can you do that in serdes? I doubt it. For such high sinusoid you need to find solutions from RF people. - Altera_Forum
Thank you for fast reply Kaz ... Yes, I have a signal to be up-converted inside the FPGA. I don't know about serdes, if it possible or not!
now my question is how high frequency,roughly, I can get from (LUT or NCO) as a carrier frequency. I tried to make the up conversion in Matlab and just store it at the LUT but I realized that I'm having different frequency from the HSMC output.. so I started to wonder about how high I can get! - Altera_Forum
It depends only on your Fs (clock). The highest sine frequency for on given clock is half of that clock i.e. when you sample only two data points per sine cyle from LUT.
Thus if you want higher freq you need higher clock(for same LUT) - Altera_Forum
--- Quote Start --- I was just wondering about how high I can get as an output from the the Stratix III Development Kit as a carrier frequency. I know I can use two ways to generate that signal using (nco or .mif file for the simulated signal from Matlab), and I'm really hoping to get something close to 1GHz (for example) if it possible! --- Quote End --- Please explain what you want the 1GHz carrier for, and we can provide some advice. For example, the carrier can be generated using an digital-to-analog converter (DAC), or an external direct digital synthesizer (DDS), or an external phase-locked loop (PLL) (with low-jitter VCO). The design depends on your jitter requirements and whether you need to program the frequency, etc. Cheers, Dave - Altera_Forum
--- Quote Start --- I have a signal to be up-converted inside the FPGA. --- Quote End --- What is the signal bandwidth? --- Quote Start --- now my question is how high frequency,roughly, I can get from (LUT or NCO) as a carrier frequency. I tried to make the up conversion in Matlab and just store it at the LUT but I realized that I'm having different frequency from the HSMC output.. so I started to wonder about how high I can get! --- Quote End --- FPGAs can be used to process samples in parallel, so the frequency of the FPGA does not have to match the frequency of the signal. I have systems that process 1GHz clock rate sampled data; inside the FPGA, the data is processed at 125MHz clock rate, with 8 samples processed every clock. I am currently testing 20GHz clock rate ADCs, where 128 samples are processed every clock at 20GHz/128 = 156.25MHz, or 64 samples are processed at twice that frequency. In the case of a narrow bandwidth signal that needs to be modulated to higher frequencies, you can use multirate sampling filters. Cheers, Dave - Altera_Forum
Now I get it ... Thanks for the help :)
Though parallel processing is an option but I doubt achieving 1GHz. You may split up signal path into 4 branches at 250MHz each but there will be dependency especially with filters and I doubt if this practical. I prefer to go as far as 300MHz clock at best thus restricting myself to about 100+MHz sinusoid including signal bandwidth.
Dear Dave,
my signal bandwidth is about 100MHz ... I already have a signal generator that provides me with 3GHz carrier frequency but I just want to up convert my signal twice once inside the FPGA and twice by the signal generator. I will try to change my Fs and see how much I will get. Thanks, - Altera_Forum
--- Quote Start --- Though parallel processing is an option but I doubt achieving 1GHz. You may split up signal path into 4 branches at 250MHz each but there will be dependency especially with filters and I doubt if this practical. I prefer to go as far as 300MHz clock at best thus restricting myself to about 100+MHz sinusoid including signal bandwidth. --- Quote End --- Sure its practical. I have ~600 Stratix II FPGAs synchronously processing 4GHz of sampled bandwidth across 120 boards, and another ~1000 FLEX10KE FPGAs (yeah, that old) processing another 8GHz (all using 1GHz clock rate ADCs and parallel processing); see p25 of these slides (p27 of the PDF) http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100slides_hawkins.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-100slides_hawkins.pdf) Not cheap, but practical :) Cheers, Dave - Altera_Forum
--- Quote Start --- my signal bandwidth is about 100MHz ... I already have a signal generator that provides me with 3GHz carrier frequency but I just want to up convert my signal twice once inside the FPGA and twice by the signal generator. I will try to change my Fs and see how much I will get. --- Quote End --- You will need to convert it to an analog signal first. How do you plan on doing that? How will your signal get off the FPGA to the 3GHz carrier? How were you planing on modulating the signal; single-sideband mixer, quadrature mixer? Where does your 100MHz need to end up in analog frequency? Cheers, Dave
