15 years agoThe Highest Carrier Frequency for Stratix III
Dears All, Greetings, I was just wondering about how high I can get as an output from the the Stratix III Development Kit as a carrier frequency. I know I can use two ways to generate that...
15 years ago --- Quote Start --- Though parallel processing is an option but I doubt achieving 1GHz. You may split up signal path into 4 branches at 250MHz each but there will be dependency especially with filters and I doubt if this practical. I prefer to go as far as 300MHz clock at best thus restricting myself to about 100+MHz sinusoid including signal bandwidth. --- Quote End --- Sure its practical. I have ~600 Stratix II FPGAs synchronously processing 4GHz of sampled bandwidth across 120 boards, and another ~1000 FLEX10KE FPGAs (yeah, that old) processing another 8GHz (all using 1GHz clock rate ADCs and parallel processing); see p25 of these slides (p27 of the PDF) http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100slides_hawkins.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-100slides_hawkins.pdf) Not cheap, but practical :) Cheers, Dave
