15 years agoThe Highest Carrier Frequency for Stratix III
Dears All, Greetings, I was just wondering about how high I can get as an output from the the Stratix III Development Kit as a carrier frequency. I know I can use two ways to generate that...
15 years ago --- Quote Start --- my signal bandwidth is about 100MHz ... I already have a signal generator that provides me with 3GHz carrier frequency but I just want to up convert my signal twice once inside the FPGA and twice by the signal generator. I will try to change my Fs and see how much I will get. --- Quote End --- You will need to convert it to an analog signal first. How do you plan on doing that? How will your signal get off the FPGA to the 3GHz carrier? How were you planing on modulating the signal; single-sideband mixer, quadrature mixer? Where does your 100MHz need to end up in analog frequency? Cheers, Dave
