16 years agoThe Avalon master interface
i meet two timing diagram about the master interface and i think the frist one is right,but the secend one appeared in a lot of datasheets.
is there anyone can suggest me? thank you in advance!6 Replies
both are correct
the left one shows read_n and the right one read the difference is, that read_n is the inverted read signal, that why there is a little _n suffix for negate also the left shows waitrequest_n with readdatavalid_n and the right one waitrequest to understand the difference you might have a look at the avalon specification manual - Altera_Forum
Both are valid in the Avalon-MM spec: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf
If you are creating your own master component make sure you identify your read (or write) signal as either "read" or "read_n" as a signal type depending on whether you use normal polarity (read) or reverse polarity (read_n). As long as you select the type correctly SOPC Builder will know what to do with that signal when it goes to hook it up to the fabric. - Altera_Forum
You just want a master interface with the following signals?
- r_address - r_read_n - r_waitrequest Seems that your "r_read_n" signals in your diagram should be named "r_read". - Altera_Forum
If a signals suffix with "_n" that means that signal is active low.
If a signals suffix with "_n" that means that signal is active low. When the master assert a read command for "read" signal : it goes from low --> high ==> active high for "read_n" signal : it goes from high --> low ==> active low - Altera_Forum
I have make it,thank you.
