16 years agoThe Avalon master interface
i meet two timing diagram about the master interface and i think the frist one is right,but the secend one appeared in a lot of datasheets. is there anyone can suggest me? thank you in advanc...
16 years agoIf a signals suffix with "_n" that means that signal is active low.
If a signals suffix with "_n" that means that signal is active low. When the master assert a read command for "read" signal : it goes from low --> high ==> active high for "read_n" signal : it goes from high --> low ==> active low
