21 years agoStill having strange problems with SRAM and FLASH
I am still dealing with problems of unknown nature on my custom board.
Maybe somebody will have a bright idea how to move forward a little: My custom board based on Cyclone C6 consist of internal 4k ram (int_ram), external CFI flash, external SRAM (both on the same Avalon tri-state bus). I have prepared a small hosted C-code to run SRAM memory test and flash some LEDs to show progress and the test results... Code is tested and works ok. When I build NIOS II to boot from an EPCS controler or an external CFI Flash but execute from int_ram everything is fine. My code works great, goes throug the SRAM memory test routine and test ends with a success. From this experiment I would find: 1. CFI flash is configured correctly because: - I can erase it, program it and verify it with no errors - I can store the my code and copiero code there - I can run copier program from CFI Flash fine - I can copy code from CFI Flash to int_ram and it works ok 2. My SRAM is configured correctly because: - my C-code goes through all SRAM addresses and reads 32-bits patterns of aaa.../555... previously written - my C-code goes through "walking 1s" routine for each SRAM address and it checks out ok. but... When I build NIOS II to boot from external CFI Flash and execute from there, my code does not work. It does not matter if I link .rodata and .rwdata partitions to go into int_ram or SRAM - it does not work. When I build NIOS II to boot from external CFI Flash and execute from external SRAM, my code does not work. I am confused here: CFI Flash tested ok, SRAM tested ok but when I am trying to run my code hosted in these devices everything falls apart. When am I missing here? BTW - My code skips first 10k of 1Mb SRAM when operates from the same memory to not overwrite itself but tests whole SRAM memory when operates from int_ram. I have also tried slowing down the cpu clock to avoid SRAM timing issues. Nothing helps.
