15 years agoSSRAM Verify failed after adding custom components in SOPC Builder
I created a system based on the template for the Stratix II Nios Kit. I took the SDRAM away since I don't have a license for that IP Core. I intended to use SSRAM since it's a small project. I compiled in quartus and programmed the FPGA then created a hello world application in Nios IDE and it compiled and run ok. Now when I add custom components in SOPC Builder like PWM and ADC interface, generate, assign pins, compile in quartus, and try to compile in Nios IDE I get verify failed at address 0x01000000.
I configured unused pins as tristate inputs and triple check pins assignments so I don't know what could be the problem. Can anyone help me please?
