15 years agoSSRAM Verify failed after adding custom components in SOPC Builder
I created a system based on the template for the Stratix II Nios Kit. I took the SDRAM away since I don't have a license for that IP Core. I intended to use SSRAM since it's a small project. I compil...
14 years agoThen you should start with the examples. If they work and your design doesn't, look for differences between the two, especially around the memory controller and the timing requirements (.sdc files).
