15 years agoSSRAM Verify failed after adding custom components in SOPC Builder
I created a system based on the template for the Stratix II Nios Kit. I took the SDRAM away since I don't have a license for that IP Core. I intended to use SSRAM since it's a small project. I compil...
14 years agoare you sure you put the correct .sof file and are compiling with the correct .sopcinfo description? Check also that the address used when downloading the software (0x400000 in the example you gave) is the correct one for your main memory.
