15 years agoSSRAM Verify failed after adding custom components in SOPC Builder
I created a system based on the template for the Stratix II Nios Kit. I took the SDRAM away since I don't have a license for that IP Core. I intended to use SSRAM since it's a small project. I compil...
14 years agoThere is unfortunately no "quick and dirty way" to do this. If you don't have a proper timing, your design may run into problems. Are you using a kit? Aren't there example designs that you can use?
