21 years agoSOPC Builder
ciao to everybody
I'm trying to build a new system with cpu nios 2 , sdram ,tristate bridge and my user component I import my component vhdl file and i declare 2 port that in slave are input but in sopc i declare "writedata" . I flag on for generate header files ect At the end i click on "Generate" and sopc gerates for me my new system After i go to check in cpu_sdk the three folders -inc -lib -src Here i can find many .h and .c files , about PIO , LCD , UART but i didn't found no one file i'm interesting How can i do? How can i interface my application C/C++ in Nios II IDE with my user component ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif thanks for helps walter ciao13 Replies
now i'm trying your example
i create a new quartus 2 project, import your vhdl file and set it as top-level , start compilation and finish good . I open SOPC builder and import this component , and declare the port slave like you wrote . Add it in my system , and ready to generate . One question : in the SOPC builder , Avalon bus slave reserve for the component 16 word registers base address =0x00000800 end=0x0000080F I use only register 0 ,1,2 ,3 , but what does they means other 11 registers? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif ciao walter - Altera_Forum
address width is 2
writedata width is 32 (4 Byte) addressrange is (2^2)*4 = 16 addresses in your case controlregister is at base address=0x00000800 reg1 (base divider) is at address=0x00000804 ... but you don't have to take this in account, if you use the MACROS IOWR and IORD. e.g. IOWR(AV_CLOCK_0_BASE,CPU_CLK_DIVIDER,50000); calculates the absolute address AV_CLOCK_0_BASE+4*CPU_CLK_DIVIDER (in your case 0x00000800)+(4*1)=0x00000804 avalon interface is little endian "Little Endian" means that the low-order byte of the number is stored in memory at the lowest address, and the high-order byte at the highest address. (The little end comes first.) writing 32 bit (e.g. 0x12345678) into controlregister writes: *(0x00000800)=0x78 Byte0 *(0x00000801)=0x56 Byte1 *(0x00000802)=0x34 Byte2 *(0x00000803)=0x12 Byte3 hope this helps - Altera_Forum
hi fisher
yes i know little endian but i didn't understand the size of bus sizing now i understand and i'm waiting my NIOS II kit Next week i'll go in turchia for work and i'll try next time thanks Fisher http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
