21 years agoSOPC Builder
ciao to everybody I'm trying to build a new system with cpu nios 2 , sdram ,tristate bridge and my user component I import my component vhdl file and i declare 2 port that in slave are ...
21 years agoaddress width is 2
writedata width is 32 (4 Byte) addressrange is (2^2)*4 = 16 addresses in your case controlregister is at base address=0x00000800 reg1 (base divider) is at address=0x00000804 ... but you don't have to take this in account, if you use the MACROS IOWR and IORD. e.g. IOWR(AV_CLOCK_0_BASE,CPU_CLK_DIVIDER,50000); calculates the absolute address AV_CLOCK_0_BASE+4*CPU_CLK_DIVIDER (in your case 0x00000800)+(4*1)=0x00000804 avalon interface is little endian "Little Endian" means that the low-order byte of the number is stored in memory at the lowest address, and the high-order byte at the highest address. (The little end comes first.) writing 32 bit (e.g. 0x12345678) into controlregister writes: *(0x00000800)=0x78 Byte0 *(0x00000801)=0x56 Byte1 *(0x00000802)=0x34 Byte2 *(0x00000803)=0x12 Byte3 hope this helps
