21 years ago
Simple Socket Server problem
Hi All,
I tried to run simple socket server example with full_featured 1S10ES example. However, whenever [after downloading the sof file using Quartus Programmer] I click on [after selecting simple_socket_server_0 in project navigator] Run As --> NIOS Hardware, I get the following message:
nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios
nios2-terminal: II systems. You may experience intermittent JTAG communication
nios2-terminal: failures with this cable. Please use a USB Blaster revision B
nios2-terminal: cable or another supported cable. Please refer to the file
nios2-terminal: errata.txt included in the Nios II development kit documents
nios2-terminal: directory for more information.
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
//My ByteBlaster II cable works fine, so I doubt if that may be a problem//
Simple Socket Server starting up
Your Ethernet MAC address is 00:07:ed:0a:a5:9e
//at this stage seven-seg shows random patterns. But when following messages appear, it gets fixed at "97"//
[lwIP]: See STDERR for expanded diagnosis translation.
[lwIP]: [init_done_func] Fatal: lwip_devices_init failed, perhaps ethernet inter
face.
[lwIP]: ERRNO: :
[lwIP]: See STDERR (FAULT_LEVEL is SYSTEM).
[lwIP]: FAULT_LEVEL is SYSTEM.
[lwIP]: FATAL Error, Restart required.
[lwIP]: Locking scheduler - endless loop.
Also, as asked in the above messages, where do I see STDERR?
    usually, the jtag_uart is used for stdin, stdout and stderr. Refer to the system library settings in your project properties (IDE).
    The error, you get, is caused during the excecution of lwip_devices_init(...). You can find this function in alt_lwip_dev.c
    May be, you should check the processing of this function to determine the cause of the error!
    --- Quote Start ---
    originally posted by vizziee@Aug 26 2005, 09:22 AM
    [lwip]: [init_done_func] fatal: lwip_devices_init failed, perhaps ethernet inter
    face.
    [lwip]: errno: :
    [lwip]: see stderr (fault_level is system).
    [lwip]: fault_level is system.
    [lwip]: fatal error, restart required.
    [lwip]: locking scheduler - endless loop.
    --- Quote End ---
    Hey
    Did you install the Updated Ethernet Driver for NIOS which i think comes with the socket code.
    I had the same issue on my 1s10
    STDERR needs to be set to jtag_uart (same as STDOUT)
    regards
    Pavan
    Make sure, you did not change the name of the lan-adapter in your SOPC-Builder system. Easiest way to keep things running is to leave your network-adapter named lan91c111.
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    Did you install the Updated Ethernet Driver for NIOS which i think comes with the socket code.[/b]
    --- Quote End ---
    But from where do I get this?
    hmm, I had something similar. But then I noticed, I had forgotten to check under properties system library for software components: add software. IP.. have look at the light_weight_ip tutorial.pdf.
    &#39;hope I could help you.
