21 years agoSimple Socket Server problem
Hi All, I tried to run simple socket server example with full_featured 1S10ES example. However, whenever [after downloading the sof file using Quartus Programmer] I click on [after selecting si...
21 years ago --- Quote Start --- originally posted by vizziee@Aug 26 2005, 09:22 AM [lwip]: [init_done_func] fatal: lwip_devices_init failed, perhaps ethernet inter
face.
[lwip]: errno: :
[lwip]: see stderr (fault_level is system).
[lwip]: fault_level is system.
[lwip]: fatal error, restart required.
[lwip]: locking scheduler - endless loop. --- Quote End --- Hey Did you install the Updated Ethernet Driver for NIOS which i think comes with the socket code. I had the same issue on my 1s10 STDERR needs to be set to jtag_uart (same as STDOUT) regards Pavan
