21 years agoSimple Socket Server problem
Hi All, I tried to run simple socket server example with full_featured 1S10ES example. However, whenever [after downloading the sof file using Quartus Programmer] I click on [after selecting si...
20 years agohmm, I had something similar. But then I noticed, I had forgotten to check under properties system library for software components: add software. IP.. have look at the light_weight_ip tutorial.pdf.
'hope I could help you.
