15 years agosimple change nios2/s -> /e fails to load pgm
just getting started with de1
i presumed a simple change from niosII/s -> niosII/e in the count_binary example of the hardware tutorial would compile /load/ run with no surprises the program runs fine using niosII/s but if i downgrade the processor nios2/e-the program fails to load- with the unhelpfull message that appears in the forums over & overpausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused
at roughly 65% complete ... .. what am i missing ??
Does the project meet all timing requirements when you compile it in Quartus? The nios2/e core has less pipelining than the /s core IIRC and its fmax could be lower.
--- Quote Start --- Does the project meet all timing requirements when you compile it in Quartus? The nios2/e core has less pipelining than the /s core IIRC and its fmax could be lower. --- Quote End --- i had tested the both (s&e) at both 50Mhz & 25Mhz & no - timing had no negatives - Altera_Forum
The core change can't explain your problem alone... can you switch back to the /s core, regenerate, recompile and test again? Just to be sure this isn't due to a bad pin assignment.
Check also that your two systems have the same parameters (especially reset vector and exception addresses) and use the same clock domains. - Altera_Forum
I had discovered a 'bad pin' the first time round which got the /s working
moving back to /e the upload still fails - been back and forth a couple time with small tweeks - /s yes, /e no going to try with the "legacy" tool chain tonight NOTE: the fpga always installs, just loading the prgm for Nios2 fails - Altera_Forum
did you compare the reset and exception addresses between the two cores?
if you are using cache memory on the /s core, disable burst accesses, if it is enabled
