15 years agosimple change nios2/s -> /e fails to load pgm
just getting started with de1 i presumed a simple change from niosII/s -> niosII/e in the count_binary example of the hardware tutorial would compile /load/ run with no surprises the p...
15 years agodid you compare the reset and exception addresses between the two cores?
if you are using cache memory on the /s core, disable burst accesses, if it is enabled
