15 years agosimple change nios2/s -> /e fails to load pgm
just getting started with de1 i presumed a simple change from niosII/s -> niosII/e in the count_binary example of the hardware tutorial would compile /load/ run with no surprises the p...
15 years ago --- Quote Start --- Does the project meet all timing requirements when you compile it in Quartus? The nios2/e core has less pipelining than the /s core IIRC and its fmax could be lower. --- Quote End --- i had tested the both (s&e) at both 50Mhz & 25Mhz & no - timing had no negatives
