15 years agosimple change nios2/s -> /e fails to load pgm
just getting started with de1 i presumed a simple change from niosII/s -> niosII/e in the count_binary example of the hardware tutorial would compile /load/ run with no surprises the p...
15 years agoThe core change can't explain your problem alone... can you switch back to the /s core, regenerate, recompile and test again? Just to be sure this isn't due to a bad pin assignment.
Check also that your two systems have the same parameters (especially reset vector and exception addresses) and use the same clock domains.
