20 years ago
SDRAM vs. DDRAM Performance
Hi @all,
for a redesign i have to check which performance is better:
A 32bit SDRAM with the SOPC-Builder SDRAM Controller (Latency Aware SDRAM Controller Version 6.01)
or a 16bit DDRAM with the DDR-Controller (DDR-SDRAM Controller Version 3.40)
Both Systems will be clocked at 100MHz. The NIOS also. Therefore no extra clocks are generated by the Avalon-Logic. Make it sense to connect 2 Chips to the Nios to get a 32bit-Bus?
Which system has the better performance?
Thanx for your suggestions...
Bye
Marco
