20 years agoSDRAM vs. DDRAM Performance
Hi @all, for a redesign i have to check which performance is better: A 32bit SDRAM with the SOPC-Builder SDRAM Controller (Latency Aware SDRAM Controller Version 6.01) or a 16bit DDRAM w...
20 years ago --- Quote Start --- originally posted by svhb@Sep 18 2006, 03:17 PM some info can be found in followong graph : testresults (http://users.pandora.be/svhb/test%20results%20jpeg%20algorithm.pdf)
some explanations about the graph :
cpu 85 pm ddr mtxa130 dm ddr mtxa130 means :
cpu 85 : cpu speed 85mc,
pm ddr mtx 130 = program memory ddr microtronix core 130mc
dm ddr mtxa130 = data memory (stack, ...) ddr microtronix core 130mc
all cpus on 52mc are niosii in a cyclone device
all others are niosii in cycloneii
the cpu is generated as standard (s-version), with smalles possible instruction cache, no data cache (we want to test memory access here!).
the algorithme is a jpeg encoder, the different steps in the encoding are measured also. no hardware optimisations!
synchronuous sram seems to be best, but more expensive.
hope this helps.
stefaan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18322)
--- quote end ---
--- Quote End --- @Stefaan What DDR-Interface was that? 16bit? What SDR-Interface? Also 16bit or 32bit? Can you tell me more details about the hardware? Thanx Marco
