SDRAM does not retain data
I have a custom board with an altera EP1C12, a flash memory and a MT48LC4M32B2 SDRAM memory.
Timings I set in SOPC builder are the default timings for this part. When I set the value 0x00000000 to a particular location (i doesn't matter which location I choose), if I read back the same location after 5 ms (milliseconds!) I find 0x00000000; after 10ms some of the bits go to value 1; incrementally all the bits go to 1, and if I read it after 15ms, I read 0xffffffff. I tried increasing the refresh frequency (from 15.625us to 3us) with no success.#include <stdio.h># include "system.h"
int main()
long i,j;
long *sdram = (unsigned long *)SDRAM_BASE;
long test,last;
long values;
long times;
for(i=0;i<32;i++)
values=0;
times=0;
for(i=0;i<10;i++)
printf("Hello From Nios\n\n");
sdram=0x00000000;
last=0;
i=0;
j=0;
while(1)
test=sdram;
if(test!=last)
times=i;
values=test;
last=test;
j++;
if (test==0xffffffff)
for(k=0;k<32;k++)
printf("\nTime:%8ld us Value: %8ld",times,values);
break;
usleep(i);
i+=1000;
return 0;
} Any suggestions? Thank you in advance. Marco9 Replies
In my opinion, it's very strange.
But in your code you write a value to an arbitrary address of SDRAM, not dedicated to your variable...<div class='quotetop'>QUOTE </div> --- Quote Start --- sdram[43235]=0x00000000;[/b] --- Quote End --- I think u can try to allocate statically or dinamically some memory space for your variable. - Altera_Forum
Are you using a data cache? If so, you should be using the IO macros and/or the bit 31 override to circumvent the cache.
Alternately, you can use alt_uncached_malloc, which will return a pointer to an uncached location in memory. There are examples of this exact usage in the memtest software example. Cheers, - slacker - Altera_Forum
Slacker, I'm not using a data cache (I'm using Nios II/e) so I don't need to use uncached memory.
I tried using IORD/WR instructions and the result is the same:
...I noticed that using a delay increment of 1us at a time (see line "i+=1; //INCREMENT x us") , the problem appears earlier than when I use an increment of 100us: 1us output: Time: 175 us Value: 8 Time: 180 us Value: 400008 Time: 184 us Value: 40000c Time: 187 us Value: c0000c Time: 189 us Value: c4000c Time: 190 us Value: 40c4000c Time: 191 us Value: 44c4200c Time: 194 us Value: 44d4202c Time: 195 us Value: 44d4203c Time: 196 us Value: 44f5203c Time: 199 us Value: 54f7203c Time: 202 us Value: 54f7223c Time: 203 us Value: 74f7223c Time: 204 us Value: 7cf7223c Time: 205 us Value: 7cf72a7c Time: 206 us Value: 7cf7aa7d Time: 209 us Value: 7cf7ea7d Time: 210 us Value: 7df7ea7d Time: 215 us Value: 7df7ee7d Time: 219 us Value: fdf7ee7d Time: 228 us Value: fdf7eefd Time: 242 us Value: fdf7eeff Time: 253 us Value: fdf7efff Time: 254 us Value: fdffffff Time: 255 us Value: ffffffff Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 100us output: Time: 2500 us Value: 8 Time: 2600 us Value: 40000c Time: 2700 us Value: 44f4203c Time: 2800 us Value: 7cf7227d Time: 2900 us Value: 7df7ea7d Time: 3000 us Value: fdf7ee7d Time: 3100 us Value: fdf7eefd Time: 3300 us Value: fdf7efff Time: 3400 us Value: ffffffff Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 Time: 0 us Value: 0 It doesn't seem an overwriting problem. Another thing: I'm running the program on onchip memory, since if I set the reset address at the beginning of the SDRAM, I can't get debug to the first line of the code.#include <io.h># include <stdio.h># include "system.h" int main() { long i,j,k; long test,last; long values; long times; for(i=0;i<32;i++) { values=0; times=0; } for(i=0;i<10;i++) printf("Hello From Nios\n\n"); // sdram=0x00000000; IOWR_32DIRECT(SDRAM_BASE, 3578, 0x00000000); last=0; i=0; j=0; while(1) { //test=sdram; test=IORD_32DIRECT(SDRAM_BASE, 3578); if(test!=last) { times=i; values=test; last=test; j++; } if (test==0xffffffff) { for(k=0;k<32;k++) printf("\nTime:%8ld us Value: %8x",times,values); break; } usleep(i); i+=1; //INCREMENT x us } return 0; } - Altera_Forum
Sounds like a hardware issue, to me. In fact, it sounds (to me) like your memory is somehow expecting the controller to refresh it.... The Altera-provided controller, for SDRAMs, only supports auto-refresh memories and configures these memories to go into auto-refresh mode during initialization.
I would say that you have some sort of initialization issue, or, perhaps, a bad SDRAM. Continuing with a pure SW debug is a dead-end. Best of luck! - slacker - Altera_Forum
I think you are writing to somewhere other than SDRAM. The MT48LC4M32B2 is a 128M-bit device organized as 4M x 32 bits. So, I think the highest index into a long array is 4095, and an index of 43235 points to who knows where.
I would use the debugger and check to see what locations actually get written when using index 0, 1, and 2 to start with and check memory after each write. You could also make your array pointers to integers or characters, and thereby increase the number of accessable elements (4096 longs (32-bits each) is the same as 4 x 4096 chars (8-bits each). - Altera_Forum
Marco,
The description of your problem suggests that may be an issue with the SDRAM timings. Things you need to check: 1) verify if the time settings in SOPC builder correspond with those in the chip datasheet (do not randomly try different values, just use the ones given in the datasheet); 2) adjust the phase for the SDRAM clock (I'm assuming you are using a dedicated clock output from the PLL) - this is very important in order to get it to work. Usually a negative phase in the range [-pi/3:-pi/6] for the SDRAM clock works for me - you will have to use a scope and little experimentation here, because this is highly dependent of the physical characteristics of your board and the clock speed. Also you mentioned that if you set the reset address at the beginning of the SDRAM the system doesn't start. This is normal because the reset address needs to point to a bootloader code of some sort, so you need to set this to a nonvolatile memory, or on-chip memory. Good luck C - Altera_Forum
Dear all,
thank you for your kind replies. Clancy, about 1) it should be ok, since the SDRAM I use is among the presets of the SDRAM controller module in SOPC builder. Point 2) of your reply is very interesting to me and I'm going to check it out now. I'll let you know the outcome of my try! Cheers, Marco - Altera_Forum
Well, I tried with different phase-shifts for sdram with no success. Now I'm doing the tests on location 0 of the SDRAM, even if I'm quite sure that 43235 is in the range.
Now I'm waiting a reply from the altera support.... Cheers Marco - Altera_Forum
Marco,
just want to emphasize Clancy's point regarding the SDRAM clock phase. This phase seems to be very critical (at least at higher CPU clocks), and it depends on place & route. In my specific design I had to ... 1) lock down the SDRAM-controller to a logic lock region close to SDRAM IO pins in order to freeze timing 2) adjust PLL parameters manually in the chip editor to values I was not able to get using the wizard. Failing to do so resulted in arbitrary error patterns ranging from steady failure up to passing memory tests with data read/write but sporadic failures during code execution. Rolf
