20 years agorunning application on linux system on eval board
I have difficulty in running the application on nios2 system.
The process followed is: > Built application project hell with c file hello.c > the generated .exe - hello.exe added to filesystem project created earlier - hello.exe copied to target/bin folder of filesystem project > Filesystem project built again > Filesystem proj uploaded Now, my kernel proj(done earlier) and filesystem proj are uploaded (i.e. they are into Flash- which location?) Now to runthis perticular hello.exe what I am supposed to do. *Am I supposed to download the .sof for this linux_1c20 system and then how the hello.exe will run. After conf FPGA with the .sof 7 seg LED display counter and some pattern runs on LEDs My concern is how to run this .exe in filesystem Please guide on this Thanks and Regards3 Replies
Hi
All you do is browse to the directory where the hallo.exe file is located and type# ./hallo.exe this should run the program. From other location ,assuming the hallo.exe is in the /bin directory type# ./bin/hallo.exe (I think) Good luck Rual - Altera_Forum
--- Quote Start --- originally posted by rual@Oct 26 2005, 07:51 PM hiall you do is browse to the directory where the hallo.exe file is located and type# ./hallo.exe
from other location ,assuming the hallo.exe is in the /bin directory type# ./bin/hallo.exe (i think)
good luck
rual
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10599)
--- quote end ---
--- Quote End --- I think I need to do this from nios2 terminal but when I am giving nios2-terminal then user name as nios and password as uClinux as mentioned in reference guide its giving incorrect login Pl clarify: FPGA should be configured with .sof? Thanks and Regards
--- Quote Start --- originally posted by rau+oct 26 2005, 07:56 pm--><div class='quotetop'>quote (rau @ oct 26 2005, 07:56 pm)</div>--- quote start ---
<!--quotebegin-rual@Oct 26 2005, 07:51 PM hi
good luck
rual
--- quote end ---
--- Quote End --- I think I need to do this from nios2 terminal but when I am giving nios2-terminal then user name as nios and password as uClinux as mentioned in reference guide its giving incorrect login Pl clarify: FPGA should be configured with .sof? Ok able to do it Thanks every body Thanks Rual Thanks and Regards <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10600)</div> [/b] --- Quote End ---
