20 years agorunning application on linux system on eval board
I have difficulty in running the application on nios2 system. The process followed is: > Built application project hell with c file hello.c > the generated .exe - hello.exe added to filesystem...
20 years agoHi
All you do is browse to the directory where the hallo.exe file is located and type# ./hallo.exe this should run the program. From other location ,assuming the hallo.exe is in the /bin directory type# ./bin/hallo.exe (I think) Good luck Rual
