20 years agorunning application on linux system on eval board
I have difficulty in running the application on nios2 system. The process followed is: > Built application project hell with c file hello.c > the generated .exe - hello.exe added to filesystem...
20 years ago --- Quote Start --- originally posted by rual@Oct 26 2005, 07:51 PM hi
all you do is browse to the directory where the hallo.exe file is located and type# ./hallo.exe
this should run the program.
from other location ,assuming the hallo.exe is in the /bin directory type# ./bin/hallo.exe (i think)
good luck
rual
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10599)
--- quote end ---
--- Quote End --- I think I need to do this from nios2 terminal but when I am giving nios2-terminal then user name as nios and password as uClinux as mentioned in reference guide its giving incorrect login Pl clarify: FPGA should be configured with .sof? Thanks and Regards
