19 years agoRedBoot ROM-startup linker script broken?
I've got the "ROMRAM" startup version of RedBoot running fine when loaded into RAM using gdb/JTAG. However, the "ROM" startup version doesn't work at all when programmed into flash (no diagnostic output, no network activity).
Other stand-alone programs work fine when programmed into flash, so I know the hardware works fine. Looking at the section headers for redboot.elf reveals what appears to be a serious problem. Flash is at address 0x00000000, RAM is at address 0x08000000:redboot.elf: file format elf32-littlenios2
Sections:
Idx Name Size VMA LMA File off Algn
0 .entry 00000020 08000000 08000000 00025380 2**2
CONTENTS, ALLOC, LOAD, READONLY, CODE
1 .text 0001f174 00000000 00000000 000000f4 2**2
2 .rodata 00005164 0001f174 0001f174 0001f268 2**2
CONTENTS, ALLOC, LOAD, READONLY, DATA
3 .exceptions 0000002c 08000020 000242d8 000243cc 2**2
4 .rom_monitor_rwdata 00000108 0800004c 00024308 000243f8 2**0
ALLOC
5 .rwdata 00000f88 08000154 00024410 000243f8 2**2
CONTENTS, ALLOC, LOAD, CODE
6 .bss 0002014c 080010e0 080010e0 000253a0 2**4
ALLOC The problem is that the .entry section has an LMA in _RAM_ but it has its CONTENTS and LOAD attributes set. That indicates that the program expects that sections to be initialized, in RAM, _before_execution_starts_. Since that section is in RAM, that's clearly not going to happen: only sections with an LMA in flash ROM will contain initialized values when program execution starts. How can the ROM startup version of RedBoot expect a section in _RAM_ to be initialized? Only sections located in flash should have their LOAD attribute set. The ROM startup linker script seems to be just plain broken: it is placing code in RAM. I haven't touched the linker script, so I presume other people have run into similar problems? Has anybody got fixed versions of the RedBoot ROM-startup linker scripts?6 Replies
Sorry, don't know what your specific problem is but I have run through the ecos for nios II guide using the Altera example design on the Altera dev board and the ROM configuration works ok for me.
**** IP: 172.25.170.209/255.255.224.0, Gateway: 172.25.184.246 Default server: 0.0.0.0 RedBoot™ bootstrap and debug environment [ROM] Non-certified release, version UNKNOWN - built 09:46:07, Nov 16 2006 Copyright © 2000, 2001, 2002, 2003, 2004 Red Hat, Inc. RAM: 0x01000020-0x02000000, [0x01009770-0x01fec000] available FLASH: 0x80000000 - 0x80800000, 128 blocks of 0x00010000 bytes each. RedBoot> **** Have you checked under 'eCos HAL->Nios2 architecture' in the config tool to make sure that your text and rodata region are set to your flash memory ? - Altera_Forum
--- Quote Start --- originally posted by nigelatta@Dec 1 2006, 07:26 AM sorry, don't know what your specific problem is but i have run through the ecos for nios ii guide using the altera example design on the altera dev board and the rom configuration works ok for me. --- Quote End --- Does your setup use a second bootloader to start RedBoot? When I look at the program_flash script generated when I build the ROM-startup version of RedBoot, I see that it appears another bootloader is being added by elf2flash when it is used to generate an .srec file:
I can't figure out what that bootloader is supposed to do (I'm not using it). Can anybody point me to documentation on what the boot_loader_cfi.srec file does? Neither am I using elf2flash, since I can't get it to actually generate any output. Is there any documentation on exactly what efl2flash does and why the standard gnu binutils nios2-elf-objcopy utility isn't used to convert from elf format to motorola S-record format? <div class='quotetop'>QUOTE </div> --- Quote Start --- Have you checked under 'eCos HAL->Nios2 architecture' in the config tool to make sure that your text and rodata region are set to your flash memory?[/b] --- Quote End --- Yes. That's clear from my original posting: the text and rodata sections are in flash. However, the .entry section _isn't_ in flash, and I suspect that's the problem (as I stated in my original posting). Where is your .entry section? -- Grantecho Generating flash file for device cfi_flash_0... elf2flash --silent --input=$1 --flash= --boot=`$QUARTUS_ROOTDIR/sopc _builder/bin/find_sopc_component_dir altera_nios2`/boot_loader_cfi.srec --outfil e=$TMP/ecos.flash --sim_optimize=0 --base=0x00000000 --end=0x003fffff --reset=0x 08000000 - Altera_Forum
The ROM configuration is not of much interest to us as our target board does not have executable flash, I was simply running through the example guide to check that things worked. I have not looked into the internal workings of program_flash and whatever tinkering it is doing.
I can confirm that a ROMRAM configuration of redboot, converted to srec format using nios2-elf-objcopy and then downloaded to our target using the GERMS monitor does work - but that's about as far as I have got at the moment. Info for the ROM configuration:- Elf file type is EXEC (Executable file) Entry point 0x20 There are 5 program headers, starting at offset 52 Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align LOAD 0x0000d4 0x00000000 0x00000000 0x229b8 0x229b8 R E 0x1 LOAD 0x022a8c 0x01000020 0x000229b8 0x0002c 0x0002c R E 0x1 LOAD 0x022ab8 0x0100004c 0x000229e8 0x00000 0x00108 RW 0x1 LOAD 0x022ab8 0x01000154 0x00022af0 0x00e08 0x00e08 RWE 0x1 LOAD 0x0238c0 0x01000f5c 0x01000f5c 0x00000 0x08814 RW 0x1 Section to Segment mapping: Segment Sections... 00 .entry .text .rodata 01 .exceptions 02 .rom_monitor_rwdata 03 .rwdata 04 .bss There are 19 section headers, starting at offset 0x8bff4: Section Headers: [Nr] Name Type Addr Off Size ES Flg Lk Inf Al [ 0] NULL 00000000 000000 000000 00 0 0 0 [ 1] .entry PROGBITS 00000000 0000d4 000020 00 AX 0 0 4 [ 2] .text PROGBITS 00000020 0000f4 01e054 00 AX 0 0 4 [ 3] .rodata PROGBITS 0001e074 01e148 004944 00 A 0 0 4 [ 4] .exceptions PROGBITS 01000020 022a8c 00002c 00 AX 0 0 4 [ 5] .rom_monitor_rwda NOBITS 0100004c 022ab8 000108 00 WA 0 0 1 [ 6] .rwdata PROGBITS 01000154 022ab8 000e08 00 WAX 0 0 4 [ 7] .bss NOBITS 01000f5c 0238c0 008814 00 WA 0 0 4 [ 8] .debug_aranges PROGBITS 00000000 0238c0 0016c8 00 0 0 8 [ 9] .debug_pubnames PROGBITS 00000000 024f88 002db6 00 0 0 1 [10] .debug_info PROGBITS 00000000 027d3e 024c7c 00 0 0 1 [11] .debug_abbrev PROGBITS 00000000 04c9ba 007ad0 00 0 0 1 [12] .debug_line PROGBITS 00000000 05448a 0295fd 00 0 0 1 [13] .debug_frame PROGBITS 00000000 07da88 003014 00 0 0 4 [14] .debug_str PROGBITS 00000000 080a9c 00776e 01 MS 0 0 1 [15] .debug_ranges PROGBITS 0000776e 08820a 003d20 00 0 0 1 [16] .shstrtab STRTAB 00000000 08bf2a 0000c8 00 0 0 1 [17] .symtab SYMTAB 00000000 08c2ec 002f40 10 18 153 4 [18] .strtab STRTAB 00000000 08f22c 002e15 00 0 0 1 Key to Flags: W (write), A (alloc), X (execute), M (merge), S (strings) I (info), L (link order), G (group), x (unknown) O (extra OS processing required) o (OS specific), p (processor specific) - Altera_Forum
--- Quote Start --- originally posted by nigelatta@Dec 1 2006, 12:46 PM the rom configuration is not of much interest to us as our target board does not have executable flash, i was simply running through the example guide to check that things worked. i have not looked into the internal workings of program_flash and whatever tinkering it is doing. --- Quote End --- I'm becoming very suspicious that our processor configuration isn't right. The CPU reset address is in SDRAM, so that's where the .entry section is ending up. Your ROM configuration shows the .entry section in flash along with .text, .rodata, etc. <div class='quotetop'>QUOTE </div> --- Quote Start --- I can confirm that a ROMRAM configuration of redboot, converted to srec format using nios2-elf-objcopy and then downloaded to our target using the GERMS monitor does work - but that's about as far as I have got at the moment.[/b] --- Quote End --- Thanks. That's some reassurance that I have a decent chance of getting the ROM configuration running without having to use elf2flash and the bootloader_cfi.srec file. - Altera_Forum
--- Quote Start --- I'm becoming very suspicious that our processor configuration isn't right. The CPU reset address is in SDRAM, so that's where the .entry section is ending up. Your ROM configuration shows the .entry section in flash along with .text, .rodata, etc.[/b] --- Quote End --- Probably makes sense - the Altera example design has a reset address at offset 0x0 in flash and an exception address at offset 0x20 in sdram. - Altera_Forum
--- Quote Start --- originally posted by nigelatta@Dec 1 2006, 10:49 AM <div class='quotetop'>quote--- quote end ---
--- quote start ---
i'm becoming very suspicious that our processor configuration isn't right. the cpu reset address is in sdram, so that's where the .entry section is ending up. your rom configuration shows the .entry section in flash along with .text, .rodata, etc. --- Quote End --- Probably makes sense - the Altera example design has a reset address at offset 0x0 in flash and an exception address at offset 0x20 in sdram. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19766)</div> [/b] --- Quote End --- Right. It's potentially dangerous to point a reset address at volatile memory. All of the examples point to offset 0....likely to the start of some bootloader code. - slacker
