19 years agoRedBoot ROM-startup linker script broken?
I've got the "ROMRAM" startup version of RedBoot running fine when loaded into RAM using gdb/JTAG. However, the "ROM" startup version doesn't work at all when programmed into flash (no diagn...
19 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- I'm becoming very suspicious that our processor configuration isn't right. The CPU reset address is in SDRAM, so that's where the .entry section is ending up. Your ROM configuration shows the .entry section in flash along with .text, .rodata, etc.[/b] --- Quote End --- Probably makes sense - the Altera example design has a reset address at offset 0x0 in flash and an exception address at offset 0x20 in sdram.
