19 years agoRedBoot ROM-startup linker script broken?
I've got the "ROMRAM" startup version of RedBoot running fine when loaded into RAM using gdb/JTAG. However, the "ROM" startup version doesn't work at all when programmed into flash (no diagn...
19 years agoSorry, don't know what your specific problem is but I have run through the ecos for nios II guide using the Altera example design on the Altera dev board and the ROM configuration works ok for me.
**** IP: 172.25.170.209/255.255.224.0, Gateway: 172.25.184.246 Default server: 0.0.0.0 RedBoot™ bootstrap and debug environment [ROM] Non-certified release, version UNKNOWN - built 09:46:07, Nov 16 2006 Copyright © 2000, 2001, 2002, 2003, 2004 Red Hat, Inc. RAM: 0x01000020-0x02000000, [0x01009770-0x01fec000] available FLASH: 0x80000000 - 0x80800000, 128 blocks of 0x00010000 bytes each. RedBoot> **** Have you checked under 'eCos HAL->Nios2 architecture' in the config tool to make sure that your text and rodata region are set to your flash memory ?
