19 years agoRedBoot ROM-startup linker script broken?
I've got the "ROMRAM" startup version of RedBoot running fine when loaded into RAM using gdb/JTAG. However, the "ROM" startup version doesn't work at all when programmed into flash (no diagn...
19 years agoThe ROM configuration is not of much interest to us as our target board does not have executable flash, I was simply running through the example guide to check that things worked. I have not looked into the internal workings of program_flash and whatever tinkering it is doing.
I can confirm that a ROMRAM configuration of redboot, converted to srec format using nios2-elf-objcopy and then downloaded to our target using the GERMS monitor does work - but that's about as far as I have got at the moment. Info for the ROM configuration:- Elf file type is EXEC (Executable file) Entry point 0x20 There are 5 program headers, starting at offset 52 Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align LOAD 0x0000d4 0x00000000 0x00000000 0x229b8 0x229b8 R E 0x1 LOAD 0x022a8c 0x01000020 0x000229b8 0x0002c 0x0002c R E 0x1 LOAD 0x022ab8 0x0100004c 0x000229e8 0x00000 0x00108 RW 0x1 LOAD 0x022ab8 0x01000154 0x00022af0 0x00e08 0x00e08 RWE 0x1 LOAD 0x0238c0 0x01000f5c 0x01000f5c 0x00000 0x08814 RW 0x1 Section to Segment mapping: Segment Sections... 00 .entry .text .rodata 01 .exceptions 02 .rom_monitor_rwdata 03 .rwdata 04 .bss There are 19 section headers, starting at offset 0x8bff4: Section Headers: [Nr] Name Type Addr Off Size ES Flg Lk Inf Al [ 0] NULL 00000000 000000 000000 00 0 0 0 [ 1] .entry PROGBITS 00000000 0000d4 000020 00 AX 0 0 4 [ 2] .text PROGBITS 00000020 0000f4 01e054 00 AX 0 0 4 [ 3] .rodata PROGBITS 0001e074 01e148 004944 00 A 0 0 4 [ 4] .exceptions PROGBITS 01000020 022a8c 00002c 00 AX 0 0 4 [ 5] .rom_monitor_rwda NOBITS 0100004c 022ab8 000108 00 WA 0 0 1 [ 6] .rwdata PROGBITS 01000154 022ab8 000e08 00 WAX 0 0 4 [ 7] .bss NOBITS 01000f5c 0238c0 008814 00 WA 0 0 4 [ 8] .debug_aranges PROGBITS 00000000 0238c0 0016c8 00 0 0 8 [ 9] .debug_pubnames PROGBITS 00000000 024f88 002db6 00 0 0 1 [10] .debug_info PROGBITS 00000000 027d3e 024c7c 00 0 0 1 [11] .debug_abbrev PROGBITS 00000000 04c9ba 007ad0 00 0 0 1 [12] .debug_line PROGBITS 00000000 05448a 0295fd 00 0 0 1 [13] .debug_frame PROGBITS 00000000 07da88 003014 00 0 0 4 [14] .debug_str PROGBITS 00000000 080a9c 00776e 01 MS 0 0 1 [15] .debug_ranges PROGBITS 0000776e 08820a 003d20 00 0 0 1 [16] .shstrtab STRTAB 00000000 08bf2a 0000c8 00 0 0 1 [17] .symtab SYMTAB 00000000 08c2ec 002f40 10 18 153 4 [18] .strtab STRTAB 00000000 08f22c 002e15 00 0 0 1 Key to Flags: W (write), A (alloc), X (execute), M (merge), S (strings) I (info), L (link order), G (group), x (unknown) O (extra OS processing required) o (OS specific), p (processor specific)
