Has anyone been able to get the Compact Flash working with the latest unstable release?
I am using all the same settings as my working 2.6.35 release, straight out of the wiki, same board, same .sof file, but the new 3.0.x OS, when booting, does not seem to detect nor look for the flash card.
I am also unable to get the serial console to work...quoted below is the JTAG console, which is working. It does seem to load a driver and find the port.
The .dts file segment seems to suggest the Compact Flash has been defined and seen by the sopcinfo -> dts complier.
All else I care about seems to be working...!
cf: ata@0x1000080 {
compatible = "ALTR,cf-10.1","ALTR,cf-1.0";
reg = < 0x1000000 0x10 0x1000080 0x40>;
interrupt-parent = < &cpu >;
interrupts = < 14 15 >;
}; //end ata (cf)
ALSO:
uart0: serial@0x80 {
compatible = "ALTR,uart-10.1","ALTR,uart-1.0";
reg = < 0x80 0x20>;
interrupts = < 4 >;
current-speed = <115200>; //embeddedsw.CMacro.BAUD type NUMBER
clock-frequency = <85000000>; //embeddedsw.CMacro.FREQ type NUMBER
}; //end serial (uart0)
# nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster ", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Linux version 3.0.0-rc7-01121-g1bbc9ab-dirty (Nate@NateFedora) (gcc version 4.1.2)# 57 Fri Jul 22 16:37:01 MDT 2011
bootconsole enabled
early_console initialized at 0xe1000010
On node 0 totalpages: 8192
free_area_init_node: node 0, pgdat c657b3d4, node_mem_map c6596800
DMA zone: 64 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 8128 pages, LIFO batch:0
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line:
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 26728k/5694k RAM (2245k kernel code, 3449k data)
NR_IRQS:32
Calibrating delay loop... 40.83 BogoMIPS (lpj=81664)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
Switching to clocksource timer
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
msgmni has been set to 52
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
ttyAL0 at MMIO 0x4000060 (irq = 5) is a Altera UART
ttyAL1 at MMIO 0x4000080 (irq = 4) is a Altera UART
ttyJ0 at MMIO 0x1000010 (irq = 1) is a Altera JTAG UART
console enabled, bootconsole disabled
smc91x.c: v1.1, sep 22 2004 by Nicolas Pitre <nico@fluxnic.net>
eth0: SMC91C11xFD (rev 2) at e1020300 IRQ 3
eth0: Ethernet addr: 00:07:ed:ff:ab:01
eth0: PHY LAN83C183 (LAN91C111 Internal)
mousedev: PS/2 mouse device common for all mice
TCP cubic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 2832k freed (0xc6233000 - 0xc64f7000)
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
BusyBox v1.18.4 (2011-07-22 15:00:52 MDT) hush - the humble shell
Enter 'help' for a list of built-in commands.
root:/>
