15 years agoQuestion on Git Branches to use [nios2mmu vs unstable-nios2mmu]
Hi everyone I'm currenlty looking into using Linux on the NIOS for my company. Will be getting a DE4 from Terassic shortly but in the meantime I'm doing all the prepwork to understand as much a...
15 years ago --- Quote Start --- It uses the first Altera UART device it finds as the early console. Hope it helps --- Quote End --- Good call - I moved uart0 to sit before uart1 in my dts file and all works as before now. uart1 came first by default. Still no Compact Flash. It appears SCSI drivers are compiling and loading, but there is no detect happening. I copied the 2C35 design from the wiki for the Compact Flash. It works with 2.6.35 under the nios2mmu code branch. I have a an older Nios II 2C35 demo board, not the DE2. I have tried 2.6.38 as well, no work there either. It appears the driver is the same revision. I am going to try 2.6.37, but no DTS with this revision. If anyone has gotten this to work with the unstable-nios2mmu branch 3.0.x code, please post. I would like to stay on the latest code.
