15 years agoQuestion on Git Branches to use [nios2mmu vs unstable-nios2mmu]
Hi everyone I'm currenlty looking into using Linux on the NIOS for my company. Will be getting a DE4 from Terassic shortly but in the meantime I'm doing all the prepwork to understand as much a...
15 years agoHi Turhan
Yes, let the forces combine... (3 more and we can start a Captain Planet and the Planeteers gang... haha). I won't be in front of my PC alot this week, so apologies beforehand for delayed responses. I don't think that your DTS is the problem here but rather the Kernel Configuration settings. Under the kernel configs=>Device Drivers, what settings do you have enabled under the following headers: - Device Tree and Open Firmware Support - GPIO Support - LED Support I had a quick scan through your DTS file and doesn't seem like you have GPIO LEDS in your design, so perhaps you could even try and remove all LED functionality from your kernel for now and see if it compiles then. On a different note, I see that you're using Quartus 10, which is a bit of a shame (from my perspective). I'm really strugling getting the DDR2 controller on the DE4 to work in Quartus 11 with Uniphy. Did you use the Uniphy controller or Altmemphy? Regards Antonie
