15 years agoQuestion on Git Branches to use [nios2mmu vs unstable-nios2mmu]
Hi everyone I'm currenlty looking into using Linux on the NIOS for my company. Will be getting a DE4 from Terassic shortly but in the meantime I'm doing all the prepwork to understand as much a...
15 years ago
root@rl123-c:/home/apr/work/linux/nios2-linux/uClinux-dist# make
make -f tools/autotools.mk autotools-cache
make: Entering directory `/home/apr/work/linux/nios2-linux/uClinux-dist'
make: Nothing to be done for `autotools-cache'.
make: Leaving directory `/home/apr/work/linux/nios2-linux/uClinux-dist'
chmod +x tools/romfs-inst.sh tools/modules-alias.sh tools/build-udev-perms.sh
. linux-2.6.x/.config; if ; then
mkdir -p `dirname $CONFIG_INITRAMFS_SOURCE`;
touch $CONFIG_INITRAMFS_SOURCE || exit 1;
fi
rm -f linux-2.6.x/usr/initramfs_data.cpio
make ARCH=nios2 CROSS_COMPILE=nios2-linux-gnu- O=/home/apr/work/linux/nios2-linux/uClinux-dist/linux-2.6.x -j1 -C ../linux-2.6 || exit 1
make: Entering directory `/home/apr/work/linux/nios2-linux/linux-2.6'
Using /home/apr/work/linux/nios2-linux/linux-2.6 as source for kernel
GEN /home/apr/work/linux/nios2-linux/uClinux-dist/linux-2.6.x/Makefile
CHK include/linux/version.h
CHK include/generated/utsrelease.h
CC kernel/bounds.s
nios2-linux-gnu-gcc: /include: No such file or directory
make: *** Error 1
make: *** Error 2
make: *** Error 2
make: Leaving directory `/home/apr/work/linux/nios2-linux/linux-2.6'
make: *** Error 1
Hi i am having this error my path only has this
root@rl123-c:/home/apr# echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/home/apr/work/linu x/nios2-linux/toolchain-mmu/x86-linux2/bin:
