19 years agoQuartus II 7.0 System requirements
What are the system requirements to install Quartus II 7.0. I have 1Gb of RAM and seems to be not enough to install it, I get "Program too big to fit in memory" error message. I haven't problems with version 6.1
--- Quote Start --- originally posted by tmoeltner@Mar 22 2007, 10:38 AM what are the system requirements to install quartus ii 7.0. i have 1gb of ram and seems to be not enough to install it, i get "program too big to fit in memory" error message. i haven't problems with version 6.1<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22418)
--- quote end ---
--- Quote End --- I don't have such a problem.what's your target device of your design? cycloneIII needs only 512-1024 MB memory
--- Quote Start --- originally posted by chongerfh+mar 24 2007, 04:43 am--><div class='quotetop'>quote (chongerfh @ mar 24 2007, 04:43 am)</div>--- quote start ---
<!--quotebegin-tmoeltner@Mar 22 2007, 10:38 AM what are the system requirements to install quartus ii 7.0. i have 1gb of ram and seems to be not enough to install it, i get "program too big to fit in memory" error message. i haven't problems with version 6.1
--- quote end ---
--- Quote End --- I don't have such a problem.what's your target device of your design? cycloneIII needs only 512-1024 MB memory <div align='right'><{post_snapback}> (index.php?act=findpost&pid=22476)</div> [/b] --- Quote End --- No problem for me too (got 1GB RAM).
TO_BE_DONE
It's not compiiling issue.
I installed Quartus II 7.0 in 512Mb without any problem, although I barely move one opened object in it. Better check your system. Since you had same problem on different machine, your package maybe corrupted. <div class='quotetop'>QUOTE </div> --- Quote Start --- Hardware requirements/recommendations ------------------------------------- Pentium III or later for Windows or Linux or Sun UltraSPARC-based Workstation for Solaris Memory requirements/recommendations ----------------------------------- A full installation of the Altera Complete Design Suite version 7.0 requires approximately 5 GB of available disk space on the drive or partition where you are installing the Altera Complete Design Suite and approximately 30 MB of available space on the drive that contains your TEMP directory (Windows only). The Quartus II Stand-Alone Programmer requires a minimum of 1 GB of RAM plus additional memory based on the size and number of SOF files and the size and number of devices being configured. Altera recommends that your system be configured to provide swap space (virtual memory) equal to the recommended physical RAM that is required to process your design. The following table shows the memory required to process designs targeted for Altera devices:[/b] --- Quote End --- --Quartus II readme.txt
