19 years agoQuartus II 7.0 System requirements
What are the system requirements to install Quartus II 7.0. I have 1Gb of RAM and seems to be not enough to install it, I get "Program too big to fit in memory" error message. I haven't problems ...
19 years agoIt's not compiiling issue.
I installed Quartus II 7.0 in 512Mb without any problem, although I barely move one opened object in it. Better check your system. Since you had same problem on different machine, your package maybe corrupted. <div class='quotetop'>QUOTE </div> --- Quote Start --- Hardware requirements/recommendations ------------------------------------- Pentium III or later for Windows or Linux or Sun UltraSPARC-based Workstation for Solaris Memory requirements/recommendations ----------------------------------- A full installation of the Altera Complete Design Suite version 7.0 requires approximately 5 GB of available disk space on the drive or partition where you are installing the Altera Complete Design Suite and approximately 30 MB of available space on the drive that contains your TEMP directory (Windows only). The Quartus II Stand-Alone Programmer requires a minimum of 1 GB of RAM plus additional memory based on the size and number of SOF files and the size and number of devices being configured. Altera recommends that your system be configured to provide swap space (virtual memory) equal to the recommended physical RAM that is required to process your design. The following table shows the memory required to process designs targeted for Altera devices:[/b] --- Quote End --- --Quartus II readme.txt
