17 years ago
Problem with "system ID" and "Timestamp" when debugging/running the system
I am using Quartus II/Nois II IDE v9.0 and I got this message when debugging or running my software on board:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Reading System ID at address 0x00142488:
ID value does not match: read 0x00204009; expected 0x20440F8F
Timestamp value does not match: image on board is newer than expected
Read timestamp 5:14:07 2038/01/19; expected 1:57:52 2009/09/15
The software you are downloading may not run on the system which is currently
configured into the device. Please download the correct SOF or recompile.
I made sure that the downloaded .SOF file is correct and compatible with the .PTF included in Nios II IDE.
