17 years agoProblem with "system ID" and "Timestamp" when debugging/running the system
I am using Quartus II/Nois II IDE v9.0 and I got this message when debugging or running my software on board: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target process...
17 years agoThis may be the same problem that I'm having:
http://www.alteraforum.com/forum/showthread.php?t=12697 In general, this is a problem you see when you load the wrong .sof file, as memes pointed out. However, I'm certain I'm loading the correct one, and it works just fine on an older version of Nios (6.0), but with V9.0, it does not.
