22 years agoProblem with a memory on NIOS2 idle
I would have more information about the Nios II IDLE software cause i have several problems just to execute a test soft on my prototyping board. My board contains a 10Mo CY7C1061AV33 memory Sram, a Sdram and a flash. My main problem is that i can t choose my SRAM on NIOS II IDLE software as program and data memory on the system library windows. Could you gice me some ideas ? Merci d avance http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif7 Replies
Hello XAV,
Have you setup an SOPC Builder IP module class for your SRAM , and configured it into your generated Nios System? Once that is done, the SRAM module will be included in your Quartus SOF file, and the definitions will be generated for the PTF file which is read by the Nios II IDE. I can point you to some examples of SRAM IP modules examples included in the Nios II Development kit if you like. Best regards, Stephen O'Reilly Altera Embedded Applications Engineering - Altera_Forum
Thank you so much,
I wrote a class.ptf for my sram and I add it on SOPC Builder. My Sram accept read and write access when nios runs. But IDE (when i check memory data ) disable my sram when i want put data in the Sram... So if you can help me to create a clean IP, I agree... - Altera_Forum
--- Quote Start --- originally posted by xav...@Jun 23 2004, 05:53 AM thank you so much,i wrote a class.ptf for my sram and i add it on sopc builder. my sram accept read and write access when nios runs. but ide (when i check memory data ) disable my sram when i want put data in the sram...
so if you can help me to create a clean ip, i agree... --- Quote End --- Xav, If you used Interface to User Logic to add your memory, be sure to set the bus type to "Avalon Memory Slave". This has the effect of setting the address alignment to "dynamic". In your class.ptf file, you should see something like this: Address_Alignment = "dynamic"; The IDE won't "see" your memory until you do this. Regards, slacker
Xav,
Did you get your problem resolved? Anything else we can help with? - Altera_Forum
Excuse me to be late, but I forgot to come back in the forum to watch your new message.
But it doesn t run... I don't know why! Thank you for your help. Cordialement - Altera_Forum
Hello Xav,
I don't know if this is still an issue for you.... but I've a few questions that will, hopefully, steer you towards an answer. What doesn't work? It's still not visible in the IDE or you can't access your SRAM? Or, something else? As "slacker" mentioned, in an earlier post, the IDE requires that the peripheral type be "memory slave", which has the effect of setting address alignment to "dynamic" in your class.ptf file. If this still doesn't "address" this issue, for you (pardon the pun), please post/e-mail/(PM me) with further information. Best Regards, - Brendan P.S.: Have a look in <nios2_install_dir>/components/altera_nios_dev_kit_stratix_edition_sram*/class.ptf files... That might point you towards a resolution, as well. - Altera_Forum
Did this help? Please tell us.
