22 years agoProblem with a memory on NIOS2 idle
Hi, I would have more information about the Nios II IDLE software cause i have several problems just to execute a test soft on my prototyping board. My board contains a 10Mo CY7C1061AV33 memory ...
22 years agoHello XAV,
Have you setup an SOPC Builder IP module class for your SRAM , and configured it into your generated Nios System? Once that is done, the SRAM module will be included in your Quartus SOF file, and the definitions will be generated for the PTF file which is read by the Nios II IDE. I can point you to some examples of SRAM IP modules examples included in the Nios II Development kit if you like. Best regards, Stephen O'Reilly Altera Embedded Applications Engineering
