20 years agoPCI in uClinux
Does suported PCI in uClinux for NIOS II with Altera PCI Compiler 4.0 pci_mt_32 megafuntion ?
Anywho uses this options ? I can't compile kernel with PCI support... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Thnx...21 Replies
there is no support for PCI Cores yet
I will post the driver for altera pci host bridge soon.
Hippo,
--- Quote Start --- originally posted by hippo@Mar 14 2006, 08:18 PM i will post the driver for altera pci host bridge soon. --- Quote End --- Will that include the configuration stage as well? And, how far are you? One of my customers is dying to see this. I'm perfectly willing to do a bit of work on this one, by the way. Best regards, Ben - Altera_Forum
--- Quote Start --- originally posted by bentwy+apr 21 2006, 08:02 pm--><div class='quotetop'>quote (bentwy @ apr 21 2006, 08:02 pm)</div>--- quote start ---
hippo,
<!--quotebegin-hippo@Mar 14 2006, 08:18 PM i will post the driver for altera pci host bridge soon. --- Quote End --- Will that include the configuration stage as well? And, how far are you? One of my customers is dying to see this. I'm perfectly willing to do a bit of work on this one, by the way. Best regards, Ben <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14552)</div> [/b] --- Quote End --- please check step17 in this thread, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) The PCI config is included.
TO_BE_DONE
--- Quote Start --- originally posted by bigboss25+apr 24 2006, 06:53 pm--><div class='quotetop'>quote (bigboss25 @ apr 24 2006, 06:53 pm)</div>--- quote start ---
--- quote start ---
originally posted by hippo@apr 22 2006, 10:03 am
--- quote start ---
originally posted by bentwy@apr 21 2006, 08:02 pm
hippo,
<!--quotebegin-hippo@Mar 14 2006, 08:18 PM i will post the driver for altera pci host bridge soon. --- Quote End --- Will that include the configuration stage as well? And, how far are you? One of my customers is dying to see this. I'm perfectly willing to do a bit of work on this one, by the way. Best regards, Ben <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14552)</div> [/b] --- Quote End --- please check step17 in this thread, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) The PCI config is included. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14564)</div> [/b] --- Quote End --- Hippo, do you mean that your driver will be written for Altera PCI Compiler 4.0 pci_mt_32 megafuntion ? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14597)</div> [/b] --- Quote End --- Yes, it is. I had the altera pci core in host bridge mode working on my boards.
i have a custom board with the Altera PCI Compiler PCI Core in Host-Bridge-Mode and one Gigabit Ethernet Controller connected to the Bridge. The Gigabit Ethernet Controller ist the Intel RC82540EM Ethernet Chip with Legal-PCI Bus. I have fixed the ALTPCI.C-File and the Kernel detects the Ethernet Chip. The Kernel says: *******************snipp******************************************* Autoconfig PCI channel 0x02157bd8 Scanning bus 00, I/O 0x86300000:0x86400000, Mem 0x86100000:0x86200000 00:01.0 Class 0200: 8086:100e (rev 02) Mem at 0x86100000 I/O at 0x86300000 map slot 1 pin 1 irq 15 Setting IRQ for slot 0000:00:01.0 to 15 *******************Snapp******************************************* As you see, the Intel Chip(Vendor 8086, Device 100E, Revision 2) was found on the PCI Bus. So i think the Bus-Hardware works fine... The Ethernetchip then is attached to the Avalon-Addressspace and i can read and write the Configuration Space of the Ethernet Chip. (PCI-Base is 0x8600000, The Ethernetchip Configuration is then at 0x8600800). I can read and write it without problems.... But then, when the driver of the Ethernetchip (/NET/E1000) wants to setup the Ethernet Controller the Kernel says: *******************snipp******************************************* Intel® PRO/1000 Network Driver - version 6.3.9-k4 Copyright © 1999-2005 Intel Corporation. ID: 34986200 PCI: Enable Device PCI: Device is enabled... e1000: 0000:00:01.0: e1000_probe: The EEPROM Checksum Is Not Valid e1000: probe of 0000:00:01.0 failed with error -5 *******************Snapp******************************************* The EeProm is programmed orrectly. But the Ethernetcontroller is not accessible over the Mem-Mapped Adress 0x86100000. The driver wants to access the first Control-Register at this address.... Wenn i read (with INL()) the Adresses i get: *******************snipp******************************************* Adresse: 0x86100000 Data: 0x100000 Adresse: 0x86100004 Data: 0x100004 Adresse: 0x86100008 Data: 0x100008 Adresse: 0x8610000c Data: 0x10000c Adresse: 0x86100010 Data: 0x100010 Adresse: 0x86100014 Data: 0x100014 Adresse: 0x86100018 Data: 0x100018 Adresse: 0x8610001c Data: 0x10001c Adresse: 0x86100020 Data: 0x100020 Adresse: 0x86100024 Data: 0x100024 Adresse: 0x86100028 Data: 0x100028 Adresse: 0x8610002c Data: 0x10002c Adresse: 0x86100030 Data: 0x100030 Adresse: 0x86100034 Data: 0x100034 Adresse: 0x86100038 Data: 0x100038 Adresse: 0x8610003c Data: 0x10003c *******************Snapp******************************************* What is this? Anyone ideas? When i try to access the Controller over the I/O-Mapped-Space i get only the result 0x04 .... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif I hope anyone can help me.... Thankx Marco - Altera_Forum
Up..
Maybe someone has Ideas? Thanx Marco - Altera_Forum
It looks like that the chip does not repsonse to memory acces.
So the access timeout. Please use scope or LA, to look at pci bus lines, frame, irdy, trdy , ad[]. within a short pci memory registers access loop. Check the altera pci core config page 4. Try config the e1000 to a lower memory address in pci mmemory space, and check the memory access. - Altera_Forum
You have to update altera pci core config page 4, avalon config,
change the pci base address of 32 bits memory page, to the value of avalon bus address assigned in sopc builder. ie, 86100000 in your case . you should also update the io page mapping. We want to use the same address mapping in both pci space and avalon space. config space , pci base 0 , == avalon 86000000 mem space, pci base 86100000, == avalon 86100000 unused space? io space, pci base 86300000, == avalon 86300000
