20 years agoPCI in uClinux
Does suported PCI in uClinux for NIOS II with Altera PCI Compiler 4.0 pci_mt_32 megafuntion ? Anywho uses this options ? I can't compile kernel with PCI support... http://forum.nio...
20 years agoIt looks like that the chip does not repsonse to memory acces.
So the access timeout. Please use scope or LA, to look at pci bus lines, frame, irdy, trdy , ad[]. within a short pci memory registers access loop. Check the altera pci core config page 4. Try config the e1000 to a lower memory address in pci mmemory space, and check the memory access.
