20 years agoPCI in uClinux
Does suported PCI in uClinux for NIOS II with Altera PCI Compiler 4.0 pci_mt_32 megafuntion ? Anywho uses this options ? I can't compile kernel with PCI support... http://forum.nio...
20 years agoYou have to update altera pci core config page 4, avalon config,
change the pci base address of 32 bits memory page, to the value of avalon bus address assigned in sopc builder. ie, 86100000 in your case . you should also update the io page mapping. We want to use the same address mapping in both pci space and avalon space. config space , pci base 0 , == avalon 86000000 mem space, pci base 86100000, == avalon 86100000 unused space? io space, pci base 86300000, == avalon 86300000
