20 years ago
PCI 3.3V IO
I was wondering if anyone has connected an FPGA and a PCI/Mini-pci Card with the IO standard set as 3.3V LVTTL instead of 3.3 PCI? PCI is still a 3.3V standard, but I'm not sure if the drivers are physically different in hte FPGA?
Thanks ,J
    --- Quote Start ---
    originally posted by jdhar@Jun 12 2006, 08:46 AM
    i was wondering if anyone has connected an fpga and a pci/mini-pci card with the io standard set as 3.3v lvttl instead of 3.3 pci? pci is still a 3.3v standard, but i'm not sure if the drivers are physically different in hte fpga?
    thanks ,j
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16098)
    --- quote end ---
    --- Quote End ---
    I did use 3.3 LVTTL for onboard PCI. Thought the drive chart is different. There is no problem at 33MHz.
    on-board meaning you didn&#39;t use an expansion card.. the interface was contained on the board? How far away was the device?
    --- Quote Start ---
    originally posted by jdhar@Jun 13 2006, 01:38 AM
    on-board meaning you didn&#39;t use an expansion card.. the interface was contained on the board? how far away was the device?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16133)
    --- quote end ---
    --- Quote End ---
    About 2-4 inches from the fpga.
    I think a single mini-pci socket should be OK.
    But if you want to drive several PCI slots, you would better use PCI capable pins.
    did you use external components within the pci lines - as resistors to limit current or external clamping-diodes?
    --- Quote Start ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16149)
    --- quote end ---
    --- Quote End ---
    I use minimum current strength for most pins, including onboard ddr sdram and others.
    I didn&#39;t use series resisters or clamping diodes.
