20 years agoPCI 3.3V IO
I was wondering if anyone has connected an FPGA and a PCI/Mini-pci Card with the IO standard set as 3.3V LVTTL instead of 3.3 PCI? PCI is still a 3.3V standard, but I'm not sure if the drivers ar...
20 years ago --- Quote Start --- originally posted by jdhar@Jun 13 2006, 01:38 AM on-board meaning you didn't use an expansion card.. the interface was contained on the board? how far away was the device?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16133)
--- quote end ---
--- Quote End --- About 2-4 inches from the fpga. I think a single mini-pci socket should be OK. But if you want to drive several PCI slots, you would better use PCI capable pins.
